TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Re: I am at wits end with my dream car, help?
Rasta420
on November 03, 2013 at 4:59 PM
posted by iamdan012
on November 03, 2013 at 02:09 PM
Ok, so when running and you unplug the coil packs do they make the engine idle change? Report back if any do not change the engine idle, also did you try the stethoscope on each injector so you can hear them firing?
Rasta420
iamdan012
15:21:36 11/02/13
A Z32 specialty shop will be money well spent.
zellamay
15:33:08 11/02/13
iamdan012
20:23:09 11/02/13
Swap out the ecu for a known working one...
280ZuL8R
20:35:16 11/02/13
This is where I'd start too. If that doesn't do it, swap
ThunderZ
21:08:26 11/02/13
Re: This is where I'd start too. If that doesn't do it, swap
iamdan012
21:14:07 11/02/13
Yup... & keep the tools to replace those parts in the Z.
ThunderZ
12:29:38 11/03/13
A bad MAF will not throw an ECU code if signal is in range
Zvil (FL)
20:46:18 11/02/13
Re: A bad MAF will not throw an ECU code if signal is in range
iamdan012
21:09:54 11/02/13
Well here's what happened to me
Zvil (FL)
18:22:53 11/03/13
* all the compenents tested "perfectly" according to the FSM
Zvil (FL)
18:25:52 11/03/13
Rasta420
06:16:43 11/03/13
I agree with Rasta... see these links for good guides
Medallion Man
08:18:10 11/03/13
Re: I agree with Rasta... see these links for good guides
iamdan012
14:10:37 11/03/13
iamdan012
14:09:13 11/03/13
it could be your engine harness
300ZMang
14:21:55 11/03/13
Re: it could be your engine harness
iamdan012
15:18:04 11/03/13
Re: Re: it could be your engine harness
Rasta420
15:19:40 11/03/13
brittle, splice and solder... sounds like a possible answer! (n/m)
300ZMang
16:00:14 11/03/13
is it a hot vs cold hesitation?
300ZMang
16:17:11 11/03/13
Re: is it a hot vs cold hesitation?
iamdan012
18:14:40 11/03/13
Re: Re: is it a hot vs cold hesitation?
Rasta420
06:33:32 11/04/13
Re: Re: Re: is it a hot vs cold hesitation?
iamdan012
18:16:08 11/04/13
iamdan012
15:48:22 11/03/13
Re: Re: Re: I am at wits end with my dream car, help? -
Rasta420
16:59:08 11/03/13
Have you performed the power balance test?
doug8867
10:52:02 11/03/13
just to confrim.. have you checked / replaced the igniter
Medallion Man
03:40:42 11/04/13
Have you checked fuel pressure?
WhiTTe Z (NY)
16:46:16 11/04/13
Re: Have you checked fuel pressure?
iamdan012
18:17:21 11/04/13
Re: Re: Have you checked fuel pressure?
Rasta420
18:28:56 11/04/13
Re: Re: Re: Have you checked fuel pressure?
iamdan012
12:21:18 11/05/13
TheDevilZX
07:12:32 11/06/13
